  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i have no prob with 3 am starts. leaves u the rest of the day to do what u want :P
better than what i do now. 4-12 on a sat night then 8-4 on a sunday morning
ass
i managed to get the night shift last sunday for the cruise. and i got tommorow off. so if ne ones interested we are extracting the bolts that have snapped of in kyms manifold. come round and well drink and look at his car some more
Psiker
when we replaced his turbo gasket. we noticed some bolts in his manifold were loose. on closer inspection we found out the were sheared off (snapped inside the manifold. actually more inside the engine.
so we need to remove em and replac em
V-spec - i have no probs with that pm me ur mobi and ill msg ya one day
Guest
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
