  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Good work Ken - sounds like you had a good weekend.
Tell me - was the rex 'standard' like your car is at the moment? I wouldn't think so somehow...
Catch you later if anyone is still here.
Front mount , bigger turbo we believe and he is good mates with Steve harkins ( evo 3 at Wanners )
Cheers
Ken
Originally posted by SHUTO-BOY
hmm i wonder wheres 60 sec man
He was pretty tired so I think he has headed for bed. Hehehehe
Can't work out all these young people that need Nana Naps all the time.
Cheers
Ken
Oh i was evil. I was loosing big time. No had eye co-ordination lol
So... we went to mini golf at wanaroo batanic gardens, And my little neice and nefew came along ... Tegan has only started to walk and shes soooo cute, well... As troy was about to swing, I told him "Hey troy we have to get married soon so tegan can be our flower girl and be as cute as this... " Lets just say troy didnt play that hole very well.. lol.. it was sooo funny
Originally posted by Kyles
any one wanna know how to distract troy in any kind of sport. exp mini golf..?? hehehehehe
Errr , give him a flash ??
btw , the lawn bowls thing was cos I said to pwp and Niz that Troy played bowls and they said nah , gtfoh !
I said that his pic was one of the first in the Pics and Nics thread ( I think ).:)
hence the sms for confirmation. These young people that doubt my word. Hehehe
Cheers
Ken
yep for sure.
If anyones been up there.. its the hole where you have to hit it against a board and get it into a basket that takes it though to the next part.. well troy kept missing the basket lol...
but it didnt work. I have up 1/2 the way around and looked after tegs, and i think leighton whos 3 beat troy hahahha...
Guest
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
