  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
spike just got his head cought in one of his toys.
Oh guess what the little bugger did today. He was sitting just below my neck next second his heads in my cleavage and hes chewing on my bra.. i lost it laughing.. I dont think troy was impressed.. he grunted when i told him.
Ohh lucky , lucky bird.
* now wheres that weiro gone *
Spike replies
* Help , help , i'm going under *
Cheers
Ken
Originally posted by Neo
Ken
Can you recommend anyone for a front/dump fabrication. Would like to keep it tidy??
paul would be the one to ask.
I use Butler exhaust or Exhaust dynamics but the are NOT cheap.
Cheers
Ken
JOE what are you still doing here.. gez this girl will dry up and go home before you get to her.. or she will do the job herself.. get in there boy!!
or was that puncture and blow out the window ??
Cheers
Ken
Originally posted by caminperth
hey guys.. hows things.. me just had some fun at kwinana.. unfortunately it's going to cost me a new clutch.. doh!!
And another ones gone , another ones gone , another one bites the dust...
Cheers
Ken
neo - 1st run me driving car did it's best.. 13.63 @ 163km/hr
2nd run my dad had a go - got excited and cooked the clutch..
I did two more runs - both 13.7.. way home clutch was slipping badly.. 1/4 throttle in 5th gear = lotsa revs - no go... :(
looks like my new clutch is going to happen way quicker than I thought...
or did you have the same problem that guy off america pie had with the exchange student in his room had??
was that the one where he gave her a lovebite , she farted in his face and blew out the window ?
or maybe not:D
Cheers
Ken
Guest
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
