  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
neo - not on the first run.. things got a bit hot by the last one so it was pinging a little.. but to it's credit i was running 0.9bar!
as for the blame it on dad - the clutch was pretty hammered by me beforehand over the last year.. he just cooked it for the final time...
Originally posted by Kyles
what american pie did you watch??
The scene where hes on the bed sitting next to the girl and goes to touch her and blows himself.. a few times..
Watch ... ?
I was talking from experience.j/k
Cheers
Ken
Originally posted by caminperth
ken - drag racing is good - u just have to not get excited at the launch.. :(
hmmm , the more money you spend the quicker you are and the less time on the track.
Yep , that sounds like fun...
Cheers
Ken
Originally posted by Micko
Where are you boing for a new crutch cam?
Ross @ Autoclutch seems to be the go:thumbsup:
not sure.. am going to check it out tomorrow if work allows it.. ie - me not too busy... good thing is i don't have to drive to work so it can rest for a while...
Guest
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
