  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I neally bought home a kitty today. It was hugry and lost i think.
And it purred when i picked it up and it licked my arm and followed me around. Must have been starving. Walked into the middle of 15 screaming children having afternoon tea and licked the spilt milk off the concreat outside. poor thing. I took it to the vets and they said take it home and bring it back in the morning and see what it does or go put it back now and leave it. If its still there when i get there in the morning ill take it back to the vets.
paul sick? sickness is an illusion created by your mind to make your body think your sick, the best cure for sickness is to be up and about always works for me! when i sick i go gym and funnily enough i feel better after it :(
adrian :P
Originally posted by GTS-t VSPEC
Hi Ken,
Joe, There black nails, I don't have nail clippers either, where can I buy them from?
well you have to tell your self why the dog has long nail at the 1st place... does she/he live indoor?:uh-huh:
well you can pick them up at the vet or pet shop... ask for nail clipper depends on dog's size. only cost you $10~20 max.
I have clipper will does the job...(for humans) but also will work on k9.
if you take to vet; will cost you more than the clipper hahah...
black nails... hhhmmmm it's hard to see the blood vessels on that :(
adrian :P
Oh aidrain.. I WISH it was that easy ... *rolleyes*
Guest
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
