  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
niz, if ya have a yellow and don't go down before the expiration of the specific date on the sitcker, they send you a letter to hand in your number plates as the car is deemed illegal, trust me i learnt by experience luckily they extended my expiry date :(
adrian :P
Originally posted by rob77
Whens it get here ken? I'm keen to have a look and drive if possible? Or you can take me for a drive :(
Next week it will be back from Sydney.
Have 2 guys who have first dibs on it ( thanks lumpy ) but you can certainly have a look at it.
I have bought in 6 GTR's in 2 years and even the grade 3.5 's needed work and they were 92's and 93's.
Would be surprised if the 89's didn't need at least the same if not more. If they are mint examples they go for a lot more than 700,000 yen or so. Check the dealer prices and yahoo japan for a truer indication on the good ones.
Cheers
Ken
I paid 550,000 yen for my r33. It was dead stock when it got here and was listed as a grade 4. Apart from 1 pin dent, which I think happened on the way here, it was a grade 4 car. Since then and a few australian carparks later its got 1 more pin dent, a paint scrape (that should polish out with a cut and polish) and a small dent in the drivers side door. I think I paid a pretty high price for a 94 dead stock car, but the condition is excellent.
Guest
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
