  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey there russ, rob, ken, anyone else...
Ken - I got enough backlash in my rear diff that I should get it attended too. Had the car on a hoist at a local performance shop the other night to check it out. I was told that it was prolly something to do with a spacer type thingo (sorry cant remember exactly) that would need to be replaced inside the diff where the tailshaft connects. I think it is compliments of a lack of experience launching the car from the one time I went to the drags.
Anyway - to cut a long story short - can you tell me where to go?
Yep can do but your wife has already done it for me...
Is the diff noisy?
The spacer thingy is probably the crush washer for the pinion bearing.
My advice is to just turn up the radio a bit louder. Removing , o/hauling and while it's apart , replace the clutch packs , carrier bearings , reset the preload etc then the figure will be in the $1300- $1500 region.
Get a 2nd hand one and be ready to throw it in if you run out of radio volume.
Cheers
Ken
Originally posted by rob77
My driveshaft needed 3 new unijoints when it got here, they were all fubar'd and made the car vibrate. Place in osborne park machined them and replaced them for around $360 all up. Driveshaft Balancing I think the name was.
One of the few places I know is Diff and Trans in Jolimont.
Know a few tailshaft mobs but they are not diff rebuilders.
Cheers
Ken
Thanks guys.
Ken, there's no noise, & I think it was the crush washer that they were talking about. I wouldn't care about it except that I was told it could cause excessive wear on the crown wheel (I think that's what it's called).
But then again - drive it till it breaks then get one 2nd hand for around $500 bucks I reckon.
Originally posted by Micko
Thanks guys.
Zachary...
You one smart cookie boy:D
Cheers
Ken
Ken - I'm gonna check out Gav's mines ecu on sunday & will prolly be doing a deal with him. He reckons it gave him around 300rwhp on SST's dyno.
In conjunction with what.
Std they are around 200-220 hp at all 4 . Would be surprised if just a puter made that diff.
Cheers
Ken
Originally posted by 33Spec2
haha so true ken!:D where paul and aidwin these days? and they call themselves whores!!
Paul and Aidwin , both MIA.
ewww , that conjures up some horrible images.
No Niz either. Hmmm , a 3 some.....
Cheers
Ken
Let me know if you stumble across a diff in your travels Ken - if you see one for the right price it would be worth me buying for when either of us have a need for one :D
I gotta spare , it's in the ricer.:D
Actually ,C Red have a few for around the $800 mark and I think they may even have a 1.5 or 2 way.
Cheers
Ken
Guest
    • I would never run E85 without an ethanol content sensor. Just not worth the headache. Having to reflash the tune and only refill the tank when it's very nearly empty is super annoying.
    • It’s time to take her out more on weekends!!  First thing is a wash. I’ve got my citizenship ceremony this weekend and I’m going to roll up in her 😂😝 Next up will be getting the mechanic to look at my fuel sender O ring around mid-March. I’m saving up for a different front bar so that would be after that. But she’s running happy, so I can sleep easy and slow down. Not chasing power for now.    yeah, I’d like to take her down to some meets. but when you’re not on social media anymore, it’s not easy to find those out on time 😂
    • From this comment, I'm assuming you're on the MHD platform. Put it this way, $1k is cheaper than putting a hole through the block.
    • Long time no post! Well, I never thought I'd see the day but here we are...
    • High ethanol concentrations all the time is bad for the fuel system. Not because ethanol has some inherent issue assuming you've done your fuel system setup correctly, but because PIB isn't soluble in ethanol and it contaminates the entire supply of fuel in practice. It is soluble in gasoline so you want to run a tank of normal pump gas every so often to flush all of that out before it causes an injector or something to clog.
