  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
not really but he did a little 'sing along' to the radio on the way home.
Was it Naomis choice of song? Would have been Led Zeppelin. God that woman has got good taste ( except in Husbands ) Hehehehe
Cheers
Ken
Originally posted by Nizmo
good evening all? :D
Evening Niz and thanks for the party invite. Had a good time and cos I was sober when I got home there was no problem.
I see that Mel didn't improve as the night went on. I bet she drove the porcelain bus a few times. Hehehe
Cheers
Ken
yeah she drove it in the morning - haha geez she makes even me look sober :D oh well its better her be drunk otherwise shes really normally quiet.
No probs for the invite - thanks for your company :)
Happy birthday Troy
Hello Kyles
i had controll of the radio ken :D hehe.. Nothing on at that time of night
Hi niz,
Troy get your birthday arse on mirc :)
Nite Cam.
You 2 off for some private internet sex and flirting.
Why don't you stay here like before?
Cheers
Ken:D
Hmmm , then Mel must have been well on the way when I got there cos she wasn't quiet then and that was only 8.30 .
Would have been fun to stay and stir her up but alas, the trouble and strife beckoned.:D
Cheers
Ken
Internet bonking, na he can hold out untill the weekend :D hehe.
We are going to see "he died with a falafel in his hand" on friday night :)
A WHAT in his hand ??
Cheers
Ken
yeah well what happened is she got there at 7pm with chantelle i just got out of the shower at that time cos i had a nanna nap before and i then realised there was cooking etc to be done so i was running around like a chook with its head cut off and my friends decided to instead of helping on my birthday they would watch me and start drinking. So i didnt start drinking til just before ken got there :D
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
