  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
If i know the answer......I will tell him till im black and blue and he wont believe me untill hes got 10 ppl that have said the saME THING....
hehe i dont really know hes progress 1 day his water pump and radiator is gone the next day he needs a comp test and the next day hes running high boost no probs.....??
i give up
I failed teaching the apprentice
theres no hope
I was told to get 6's but not resistor type.
In the past I have been told to use the exact same plugs that you recommended above ken.
When I think about it - he didn't specify ngk, so maybe i got things arse about (i.e. should have gone a colder plug).
I had a set of BCPR7's but I GAVE them to troy - otherwise they would be in the car now...
My car is birtually stock so i reckon i should be using stock plugs - end of story.
macka - i didn't come over because you couldnt guarantee me a shag, so i chose to stay home & take my chances
i give up
theres no hope
Yep but people get pissed off giving advice and being ignored, especially for every thing that looks like it's going wrong.
Boosted RB 26 found out about that.
Cheers
Ken
Why would Hippy recommend a NON resistor when NGK itself says use them.
If he is using anything BUT NGK , find a new dyno shop.
Nissans do NOT like running anything else, especially Champion or Bosch.
Cheers
Ken
one whole page?
your dreaming....
I meant at night anyway
jeez i gotta spell everything out!
If taht's an offer then thankyou and I retract everything I said about you to everybody at Niz's party.
But brownie points are there for the taking so will get some. Dinner and the movies I think.
Cheers
Ken
I better stop asking about plugs now before you tell me I ask too many questions & don't listen.
Just gets confusing when people tell you to do different things.
I'm gonna go get some BCPR7's tomorrow cos hendo told me they are the right plugs as well - that's why i bought the last set of them & I know they work.
btw - i thought they come in 11's (1.1mm gap) or with no number at the end which is 0.8mm???
Possibly but hey , I only went with what hendo told me.
I should check with Lumpy but won't be able to till Monday.
Cheers
Ken
Guest
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
