  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
heylo whoreseses.
sorry to hear about your motor aidwin..
nice cruise yesterday. I think all that came along would agree. glad the sun came out and dried the roads up.
really enjoyed those curvy bends on that road through araluen.
plus, we drove past my old hous when cam overshot the turn off pickering brook rd.
they have a tramampoline now.
Dammit too many "Neo"s around nowadays i cant tell one from the other.
The weather has been nice all week 3am its cleared up the roads are relatively dry and its cold as. U dont even need a cooler :) man i love winter
my normal driving headlights are pissweak. Like "i cant see sfa" sorta pissweak.
bought 100w normal type H1s from marlows yesterday and put one of them in before noticing that they say "only use 55W H1s with poly headlights".
so:
1. are the 100w globes ok to use (they dont even really seem any brighter ffs), or are they gonna melt my wires or lights?
2. are the mega spensive bluey or extra white $50 type ok to use? are they any better?
3. are the $50 type ok to use off the factory wiring, or will I need to wire them diretly off the battery and use the wiring for the factory lights as a trigger for a relay?
Guest
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
