  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Mr Cam
mmmm cant concentrate on criteria thingy - have to get in to work early tommorrow anyway to print it (home printer buggered) might finish it off then :)
*this is why i never went on to further schooling - way short attention span
all set? nah.. was just gonna fuel up and bring a fistful of $$ :)
the amount of work i've had on and the weather has stopped me sorting out the plugs issue - which is the only real thing i'd change at the moment.. shouldn't cause a prob on sat...
well i tell aidwin what i told u: Maybe its time u started wearing a wig, false eye lashes and a couple of socks shoved down ya shirt :)
I keep on wondering for how long tho til my luck is gone .......... its just multinovas that are screwing up my points!! Maybe the copper that tried to hit on me has spread the word to the other to leave me alone haha
Guest
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
