  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
Of crashing. Yeah it has an airbag - but when I hear a crash on the TV - I am pyshically sick, if I come up a bit quick to another car all I see is the accident. If I am driving and its stressful - like heavy rain or something I can;t breath properly. I never used to be like this - i was confident before
Liz I have been in more accidents than most ( usually as a navigator ) but found that by having confidence in your safety equipment and your self , the fear subsides fairly quick.
With the amount of times I have been in a roll ( bout 25 ) I worked out I am not destined to die in a motor car.
Cheers
Ken
Originally posted by SHUTO-BOY
i think we should organize some sorta wet skid pad day
-my friend fully crashed his s15 the other day because he lost traction and panicked,did the wrong thing and braked..and flipped his car
Unfortunately , there is no one in Perth who has a skidpan.
When it rains at the MC track , it's great fun though.
Originally posted by caminperth
lol @ ken.. after 25 rolls (separate occasions?!) then i'd say you have a correct hypothesis.. :D
Nah , 1 rotation is a roll. Was in a Triumph herald ( shaddup ) rally car that went over 31/2 times and caught fire.
Wrote off my rx7 rally car at a Sth Australia rallysprint with a 31/2 ( including 2 in the air ) .
Targa was 1 or so in 2001.
2 with my dad in a Datsun 1600 rally car
The list goes on...
Cheers
Ken
wow got some crazy friends hope the he comes out of his coma shortly.
hehe find a fwy liz n give it ago - only took me three days to find the accelarator but once u hit boost hehe you'll never drive like a grannie again :D
sneeza-just recently,
cam- we just need the water spray piping thingy at the edges of the area- u wanna open a drift school?
Drift school is coming.
We are putting together a proposal to run a drift series at the new MC complex at the airport.
Cheers
Ken
Guest
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
