yeah the 33's are a bit of a whale but no more than the R34s and i have a clip of an R34 doing some crazy drifting action at work - makes it look so easy!! Also have one of a monaro drifting - must admit didnt do too bad :D so if a monaro can drift any whale can drift if set up correctly
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
but still,i dont think a whale would make a good drift car
Any rwd car set up right makes a good drift car.
Nite Cam and I am off shortly too.
Niz , I assume the accomodation arrangements for Albany is the same . ie you are staying with us ( my wife and I for all you dirty minded little people out there )
Cheers
Ken
Guest
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
