  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I just can't see a manufacturer saying .... Ok lets install some blanking plates through our cars in case the people that would like to purchase them want top install aftermarket switches....
Hmmmm your probably right but the switch just looks so factory its not funny.
never stopped us talking about it before haha
yeah i got blanking plates in my car - but ive been in other skylines and where i have blanking plates they have things - where i have buttons they have a blank spot - all they do is produce the base model then install the switches according to whether its Vspec, Manual, Auto etc :) So where u have a blank spot - on another model it aint blank :D
i'll do the washing but stuff the ironing :D ex always had a bit of trouble getting me up at 7am in the morning to iron his shirt - always greeted back with a "f off if u were dumb enough not to ask me last night it aint going to happen this morning" haha
Originally posted by GTS-t VSPEC
Troy, I was impressed to see you working on Micko's car the other day, never seen you get your hands dirty before:p
pulling pipes off and afm's etc i've done b4 so seeing micko was sort of grieving even though he had this big grin on his face, and the fact i'd have to leave early i did my bit :D
Guest
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
