  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha its funny when ur 13 u wanna be 16 for your learners n other fun stuff :P then when ur 16 u want to be 17 for ur license and being a big year 12 then when ur 17 u want to be 18 haha everyones wishing their life away :)
Originally posted by SHUTO-BOY
im gonna put my boost gauge in the coin box area,and put like some sorta plastic around it
Aidwin
U might need to rethink that option re: the boost Guage.
I was gonna put mine down by the stereo in the extra DIN, until Irealised that I couldnt actually see the measurement/readout because the actual fascia is set back from the fron of the glass, and the lip obscured the numbers.
guess it depends on the guage thou.
Guest
    • Thanks everyone! I'll take the remote apart to clean the contacts and see how it goes.
    • Balance to the force has been restored.
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
