chance it'll be extended Erin?
Mine is to the 30/6 but there are talks maybe til Oct sometime now - my boss still told me not to get to comfy so im taking his advice!!
Talking about not gettting to comfy its my hometime :D
Later all
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey rob
hks controllers are a heap of bog
maybe the new ones are better.
I dont think it would matter on the needle valve too much if i laid the solenoid on an angle shaggy.
Also i dont have a duty cycle what i was talking about seems to be an "offset" to sync your reading from your ebc to your boost gauge as they are always going to be different
Spot on mate... I've been doin a bit of reading up on it aswell..
After it was playin up the other night, i pulled apart the solenoid and found a little bit of rubber stuck in the valve, cleaned it out and it runs sh*t hot now.I ended up mounting mine almost sideways in a cooler part of the engine bay.
i dunno guys.. It holds boost nicely, then suddenly drops and almost holds a lower setting.. It's too sudden and neat to be the actuator spring. Rob might be a silly question, but you've unplugged all the factory boost solenoids and crap haven't ya.. try a bleed valve and see what happens.. i would have thought the spring would drop off boost slowly as it struggles to hold it, not just drop it from 13 to 11psi instantly.
Guest
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
