  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Dam we cant do that we would be getting rid of the huge DB of information that we have accumulated in this thread :P yeh proly a good idea Jimih but i wouldnt know how to without going through each and ever post and god knows im not gonna do that. Maybe we should make vspec a mod 4 a day so he can clean up his mess:P
Boostzor,
Hey, I resemble that remark. I didn't make all the mess, just most of it.
Skyzerr,
I agree with your guidlines and will attempt to follow them, but we do get incursions from the east, which will just treat it as there own Wasteland.
Pva,
Score, lady in the red dress, she didn't turn into a Mr Smith did she?
See'ya:burnout:
Thats still what I would consider a light tune. The exhaust is an absolute must, removing the boost restrictor for 14psi is easy, and suspension doesn't affect the car too much as the factory setup is probably as good for the drags.
Either way I think it is a very good time, hope more GTR owners get out there and show what they can do. I'm looking forward to when Gtrken pulls his out for a run.
See'ya
:burnout:
GTS-t VSPEC, my best time there was 14.106 @ 101Mph with 60ft of 2.2?? and reaction of around 0.6sec, i wanted to go faster, but dont we all.....
some guys in a old VK commonwhore was giving me shi# the other day about only doing a 14.10, they couldnt stop laughing, but either could i when they started their car up and the biggest cloud of black smoke emerged from their exhaust, and hes still yelling out the window giving me crap!!!! i bet he couldnt even see thru the smoke from their car..... :D
:lol:
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
