  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah I always feel pretty safe at our cruises.... I believe that we a lot more in control of our cars than some of the "people" that attend the rolla boyz cruises...
Out of those 7 cars that were damaged at the cruise.... one of them was a 5 car pile up... the other was just a rear end between two cars...
niz starts singing sailor moon theme song "fighting evil by moonlight, winning love by daylight - never running from the real fight - she is the one named sailor moon....." haha
i used to watch it when i was 13 :uh-huh:
so what did ya tell tyre paul ..... cos he goes "So your not going with him on Saturday then?" and it took me a while to click what was happening on saturday. its like what tha? why would i be going!
Guest
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
