  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Cam,
Screamer pipes are for external wastegate turbos. With a stcok turbo the best option is to get a dump with separate internal watsegate pipe. You can get these custom made quite cheap at Genie's in Myaree.
Kym,
If you don't get a 13, then it is you and not the car. rev210 sure knows how to drive, but you won't get any respect if you don't drive it yourself.
See'ya:burnout:
Whats wrong with my whoring, whoring, whoring threads??
There just as pointless as the other shit that gets posted. Why not point out paul instead of constantly giving me shit!! I'm sick of your comments. Obviously you have somethin against me although never meeting me, but i'd appreciate it if you just lay off the constant bitching about me, cheers.
P.s, Boostzor, cypher is good. There all top blokes.
Originally posted by GTS-t VSPEC
You could do it but why? The amount of flow on the stock turbo is so small as to make an externally venting wastegate pointless. If your after wank factor then do it, will match all your stickers, haha.
See'ya:burnout:
hahaha
i just wasnt sure if there were any performance gains to be made or not, but seeing as each sticker adds 5hp, what would a screamer do?? at least 20hp, hahaha.
i wasnt gonna get one, just asking about them and there gains if any
Thanks Joe , that made it a nice quiet day in Whoretown.
Bet you pwptf and Hicks were beside themselves with grief over there inability to post large quantities of cr*p:D . hehehe
Cheers
Ken
Hey Ken, that is unfair, all the stuff I post here is brilliant and insightful, you just need to read between the lines.
Thanks for reopening Whoretown, give me the key I'll look after it. I'm sure with this spate of lockings we will all be on our best behaviour.
Love GTS-t VSPEC
See'ya:burnout:
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
