  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Wont be fitted for a while paul. I got it from works auto who was selling it for one of their customers, who they dont have a phone number for. No-one could really tell me the full story behind the turbo, simon could only tell me the guy who had it last got it off a rx7 and was going to put it on his rb20det but decided it to be too big and laggy for it. Apparently its been rebuilt recently, the only things worrying me is if its naffed (ie: needs another rebuild) and the A/R so I can find out if its going to be a lag monster. From what simon says he reckons 3500-3800 full spool up. Its going to grant on sunday/monday for him to look at and tell me what he can and also how much to fit it to the std manifold+oil lines+ext wastegate. I might get it put on sooner depending on all up costs. It was far too good a price to let it go and considering a mate of mine with a r32 wants my std turbo the change-over cost is amazing.
Guest
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
