  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Niz takes brownie point off ken :bahaha:
so einstein ..... keeping the auto transmission what is the auto subsitute?
Albert says some type of piggyback AFC which still allows the std computer to be there and control the inputs for the auto computer.
Ken hasn't got a clue...
Cheers
Ken
Originally posted by G0DF4Th3R
Niz - Cheeky!!! i saw that car is scarbs
really cos she onyl did like 50 laps :D
lets put it this way - Liz n i got there at 4pm - she was lapping - we left at 5:30pm and she was just leaving then - or i got the opinion she saw us leaving and decided to harrass us - which she failed miserably at cos she came across a bitch twice as crazy behind the wheel as her :D
was this civic black lowered mugen kit with silly silver decals on it?
if so shes a skank.
ken seeing my boost gauges are both (ie boost gauge and ebc)2psi high can i put a new gauge in and get a more accurate reading considering my boost gauge is a cheapy
Originally posted by caminperth
niz/ken - could use my afc and itc? i'm probably going to head towards power fc me thinks..
Yep , she prolly could.
Trouble with most aftermarket Replacement puters is that it is hard to keep the inputs required for the auto side of things
I doubt wolf would work and Motec or Autronic would be well over 3K
Cheers
Ken
if so shes a skank.
Probable difference was where the takeoffs are compared to what Steve used.
Cheers
Ken
Guest
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
