  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Where's Niz, I heard she's pissed at me for not saying bye, but the net cut out at Singapore and I didn't have time to reconnect:(
yeah ur in the shit man
no meeting on saturday
i'm getting confirmation of kens info about cams this week
'which puts alot of hassle and troubles in having cams affiliation'
boredboredboredboredboredboredboredboredboredboredboredboredboredboredboredbored
Originally posted by Nizmo
i would just like to say the bigger the wing the gayer it is cos it looks like u boys are trying to compensate for something.
Ahhhh the thing su can safely saywhen pwpf aint here :P
What, did you honestly think I wouldn't read this:p Bitch:D
BTW, I'm sorry I couldn't say goodbye from Singapore, my internet timed out before I could:(
Guest
