  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My clutch does occasionally make a funny noise, kinda like a shutter, but it doenst seem to worrying....
My car is getting the AVC-R tuned and dyno'd.... apparently it put out some fairly good results on the Genie Dyno..... I might take it to Steve as well to see how the readings compare if I can find the money at some stage...
Hmmm yes but I need to get from Perth to Myaree.... Hmmm... Time to ring around everyone I know :D
actually no i cant because i wiped the email i copied it from and i cant be bothered typing it all again basic story is i panicked cos there was a plastic burning smell coming from my car drove into a servo made a big fuss then realised it was a plastic bag hanging from my exhaust!
Hehe ... Niz is funny....
Paul I will do my best to pop in..... I am ringing around my friends to see if I can get a lift there today... I should get a copy of the dyno reading so it could be a good way of testing the relationship between the two dynos and readings....
How much for a power run though??? Does steve mind???
I am already putting this tuning on my credit card.... Damn getting paid monthly....
Guest
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
