  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
no.
Its on the left side of my tummy.   Dam doc needs a kick up the butt for giving it to me but :) Cant even laugh with out it hurting.. sneezing is the worst.
Hi again micko :D
tummy, geezus , how big is Troy ??
Ahh , don't bother , I REALLY don't need to know:D
Cheers
Ken
Originally posted by Micko
How did Rallymax go today Ken?
Did you show those lads how a car should be driven?
I don't drive , I instruct from the passenger seat or the glovebox.
Rob Herridge does the scary stuff at the end
Cheers
Ken
Ken - we still cant work out what is going wrong with it...
We removed the immobiliser, put in a new stereo & when I left Danny was busy tidying up the spider's web under the dash.
Still have power problems when he goes around a corner or over bumps...the car loses all power for a short time, then farts & carries on...got us both stuffed:confused:
Dont call him big boy for nothing hahahahahahhahahahhahahahaha
Yes but virginal Kyles , how would you know big if there is nothing to compare him to.
Which is why girls can't measure distance , cos they have been told that 2 is actually 12inches
hehehe
Cheers
ken
Tahts weird.
I can assure you that it NEVER did that b4.
Cheers
Ken
Guest
