  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
im good - bit depressed earlier this arvo - im ok now tho - ive been kicked out of my job because i havent sat the public service test only to get another job in the public service thats a level up - better pay n conditions - go figure! So i will have my new suspension soon that ive been whinging about yay!!
Micko break the dyno ken?
Ahh i'll probably get kicked off soon mums looking for clothing to accomadate her ever growing um behind haha nah thats mean but if she reads that she might go off in a huff and leave me the computer *evil laugh*
yep get a new job.
How i got the job in the first place: Well after waiting a year for a payrise at the last place i was working for i was earning a mere $19,000 a year - try running a skyline off that hence why its stock! I got in a huff - resigned went to QLD for two weeks came back registered with a temp agency got called back to do part time work for where i worked before - agency called me with current job because of my experience with cars would be helpful running govt fleet - i accepted - told car dealership to shove it a second time now i earn double about to add a little bit more pocket money onto that also!!
Guest
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
