  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL @ James
Yeah Stewert was Andrews middle name.
My dads side are Irish & French - so im stupid but i think im smart and apparently mums side goes back to ned kelly ...... so im a redneck thats stupid but thinks shes smart haha
But i have the good old irish last name of Lynch
yeah pity im not cooking tonight - want to do chicken .... do cheesy creamy sauce stuff on the inside ..... wrap it have bacon on the outside .... so its all wrapped in a little ball held together by toothpicks .... hard to explain but yummy.
yeah theres a few different names for it :D the one wrapped in bacon with garlic butter or just garlic butter by itself is usually mignon ..... on filled with bacon and cheese is corden bleu.
and on that note its my home time!
*hugs*
Stay safe :)
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
