  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
