how can u feel better when ur in pain?
i dont know why she asked that .... maybe she wants to employee me :D
We got a really good deal thats the main reason im going .... my friends conned me into it .... it works out ot be $14 a week and we have no joining fee - so thats no too bad.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
u are Brett - true u just keep disappearing on me haha :D
u are now adorned as one of the regular whores *brett gets on one knee - Niz knights him - big ceremonial party - everyones happy* :)
there mustnt be as much gravitational pull in QLD as there is in WA either that James scales are out! :D
i thought it had a nice ring to it too - at first i was going to try and incorporate ur trakky daks somewhere into the title - but i thought i would make it short n sweet for ya :)
must have a nice fast metabolism james :D
considering what i eat & how little exercise i do - i should look like a side of a house! Im not too bad still can fit into a lot of the clothes i used to wear when i was 16 ..... could use a tone up thats for sure!
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
