  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
cam - you seriously need to do your homework on fuel regs and pumps.
Increasing the pump strength will assist in delivery of fuel pressure - but the effectiveness of this is severely limited by the stock injectors - and you need management to run other injectors.
besides this, you're probably not managing enough boost to justify an upgaded pump.
I dont know about other brands, but I know malpassi's let you squeeze more flow out of both the standard fuel pump AND out of the duty cycle of the standard injectors - and aftermarket regulators can provide a "backup" in-series regulator for the stock one (although the stock ones are pretty good anyway).
but until we start playing with post-fmic engines, both have limited use.....but might be worth grabbing if really cheap.
always had top of range oil in there so i cant say that over Mobil 1 that was in there before theres any difference..... there mightve been and im just a dumbass female that didnt feel it. *shrugs*
i dont know how many litres sorry .... my mech did it.
ah transmission oil hmmmmm ...... dont think mine is Redline .... i dun know ...... *runs to check service invoice* hahaha really should pay more attention when Slako talks about what he's done to my car!
Hey Erin - u always come on around my hometime - the indian pacific goes to perth but leaves from sydney. :D Left u an email for u in morning.
I have to go home now
*hugs*
Lauren
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
