  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Thanks :O
Well I hate to start all this fondue action and leave but I will be off shortly as its 12.30 over here and I still have to pack and head off to bed so I can be all organised to finish my training and get to the airport on time tomorrow.... :D
I have re-organised my flights tonight.... I am now catching an earlier flight home, although it does have a stop in adelaide I get home quite a few hours earlier.... I was looking at it but wasnt sure how many people would be interested in the midnight cruise???? But yes I will defianately be back for it..... Are you interested in going???? Do you know anyone else who is going???
Guest
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
