  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
huge difference coz of older age, price drops dramatically, make sure ur listed as a frequent driver though :D so if anything does go wrong they can't screw ya over by saying that u weren't insured to drive that car :(
adrian :D
Guest
