  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
not much, had a spare bumper ready to go, and they did a bit of impromptu panel repair in the shed to make it look semi sorted, someone mumbled something about it hitting a pannel shop ultra early tom morn before it gets loaded onto the truck, but it wasn't to bad, nothing a ratchet strap a hammer and some rolling of the car backwards to pull stuff back into shape didn't fix..
Originally posted by GTS-t VSPEC
Ken, You not busy at Maximum anymore?
Always busy but always keen for variety ( in job, cars and women.... ):P
I only work subcontract so I come and go sort of when I want
Cheers
Ken
Originally posted by XRW
let me just print a copy of this for your wife, what was her name again ken? :P
Let me see..
What shall I tell Jules about the deep and meaningfuls and how sleepy they make you ...:D
Cheers
Ken
Originally posted by Micko
No Paul - danny never called up about the pipe
Ken - you checked if you got one?
Micko , I have pretty much all the terb set up off the old ones so I assume the pipe you want is here.
Don't know if it's bent though.
Cheers
Ken
Guest
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
    • Oh, right. In that case there is no rush. It's the car entries that are quite limited and can sell out quickly.
    • All I want to do is be a spectator and check out the cars in the show and shine
