  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Micko, It shouldn't be too bad if you know what your doing, but your lucky your car will be cold, mine will be boiling by the time I get it to you.
I'm going home, over at the folks, so I'll be off air for 30mins, don't miss me too much:p
See'ya:burnout:
Originally posted by Micko
you got a filter removal tool paul?
Micko,
Unless you have a very thin one or the 3 pronged one like I have , forget it.
Get pwptf to come past on the way thru and pick up the 3 prong one.
Ya got a 3/8 drive ratchet ??
And you are correct , it will piss oil over the front diff which will dribble for about 2 days.
Damn GTR's. Hehehe
Cheers
Ken
And you are correct Loz , it is friggin hot with tomorrow being hotter.
Will be in front of aircond and TV from 7.30 to 2pm tomorrow though.
Cheers
not getting the manifold done at this rate
ken
you doing the manifold today ken?
i wish i knew cos i would like to have seen how it comes apart for myself...spose it would be much harder with someone standing there asking 10000 questions:)
Nope , walked outside this morning into the garage, decided I didn't need a 8 hr sauna so went back in and clocked up brownie points.
You know , making salads , cooking and washing up for the bbq.
Us married men have got it hard compared to the singles out there.:bahaha:
Cheers
Ken
mmm had two hour nanna nap - bad dream included! Think it may be beach for my tommorrow - then again to get to beach have to drive 40mins in unaircon car on second thoughts may just stay home in heated pool n spa with cold drinks close by.
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
