  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha how was those Silvia dudes on the way back haha i pulled up beside them at the lights .... and i go "Learn to drive guys" :D and then took off haha they spen tthe rest of the time trying to catch up to me then beeped me as they turned off. Sorry about squeezing in between you n that 4wd drive .... i came pretty close to your rear end - but i didnt have to slam on the brakes or anything it was all fairly under control ..... it scared the shit outta Mel tho :D
yeah cos on mitchell freeway had to turn off to Leach hwy and they were being dicks and slowed right down ..... so i was right up their are swerving back n forth across the road then though phuck this shot past them and back in front of them .... and thats when we got to the lights to turn onto leach i told them to learn how to phucking drive haha their mouths just fell open and didnt know what to say then they went "hey" and lights changed and i booted it.
oh after you guys turned off i pulled up on leach and guy beside me in 4wd pulls up and shouts out the window to me "So did ya win?"
Cant understand why you didnt pull a "Peelie" for the RAC guy Liz mightve given you a free lube as well as your jumpstart :D
Yeah you n I pulled a few Ch33ky stunts today but its all good 'no cars were harmed in the making of this cruise' :D Knew Mitchell freeway was going to be fun.
haha nah we went to the Rivervale ..... our bottle of wine arrived before the food and i hadnt had any breakfast etc so it went straight to my head it was pretty funny ..... food there is yummy tho :D wouldve invited you but i thought you may of wanted to get your car home!
Originally posted by Sneeza
the difference between us pulling "cheeky's" and cheeky driving like a *****tard - is that we really do have skylines..
:lol:
Plus by the time you cut someone off and step on it your far far away before they have a chance to go up ya arse :D my theory anyway ..... it was a pretty risky move me shoving myself between that 4wd and you but i didnt realise the lights had turned red ..... and i started apolgising to this guy in the 4wd that asked me if i won thinking ti was him i cut off ...... but he just looked at me weird.
Hey Ken ..... yes had fun :D we always find some unsuspecting piece of shit to play cat n mouse with :D
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
