  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha i drank a whole bottle of black sambucca on an empty stomach .... then was feeling ok til suddenly i just fell to the ground n couldnt get back up .... and vomitted all over cream carpet .... it had black patches everywhere :D never drunk it again!!
Guest
