  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
WORD OF THE DAY-
Syphilis n-
A chronic infectious disease caused by a spirochete (Treponema pallidum), either transmitted by direct contact, usually in sexual intercourse, or passed from mother to child in utero, and progressing through three stages characterized respectively by local formation of chancres, ulcerous skin eruptions, and systemic infection leading to general paresis.
enjoy...
Guest
