  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
sti box possible, but given the power im going to be chasing next year, and that i want to race the car, itd split wide open soon enough, the sti 5 speed box isn't actually any stronger, it just has different diffs which give it a close ratio feel
Guest
