got a nice scenic spot near you Ross? with bbq .... pack a small picnic ... just throw together a salad .... grab a couple of steaks chuck them on the barbie open a bottle of wine ..... :) make sure its a fairly busy place with a few people to poke the piss outta of :D
herb festival haha funny ..... yeah well that would get things relaxed i would imagine!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guest
