  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Guys, you'll like this one.
I'm still in Bulgaria working on a mine. I just got a new work car with a warning that I should be careful because:
"it is a turbo and is REALLY fast".
It's a VW Passat with a 1.8 and a low blow terb (guessing only around 5psi). Supposedly produces a staggering 110 kw in a car weighing around 1600 kg!
I said that I would "respect the power".
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
