  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My baby is WELL looked after.... I am going to make her look all pretty. I can't see the point doing all this performance stuff cause I will never race, nor use it to the potential on the road. So... I know everyone will be like RIIICCCEEE... but its my car - so everyone can get stuffed hahahaha
Guest
