  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
i know i just want someone to lean on at the moment ..... noones there.
Hmmm , Cam's right.
There is a lot of people you can ask for some comfort. Depends on whether you want a friend or a lover tho...
You are only 20 and not displeasing to the eye so I would not worry and if you call Andy's protective , putdown style true love then I am a little worried about you.
Cheers
Ken
lauren so make your own plans and tell them its your party etc etc
bam we already do fall under that scrutiny and we can become a club when ever we want.
We have all the legal documents, I just have better things to put my money into atm, we want be getting cams affiliation in wa as its to much hassle and doesn't work with the way we would run are club and cruises etc.
Troy i always mean to donate considering how much i use the forums buts its something that you go - oh must do that - and gets put on the backburner for some reasonor another ..... will get my fat ass around to doing it one day tho.
Ken yeah but even Andys over protective ways can be a little more nicer than some other peoples dont give a phuck ways .... if you know what i mean :D yeha i know im only 20 but we all get a bit despondant and lonely sometimes.
ive been proactive enough in my time ..... a little too proactive .... ive done most of the stupid things and when i get like this im just likely to go back doing them again. Im ready to tell them to phuck off but it's just going to cause a whole load of shit between mel and me and i'll just end up with nobody to party with saturday night .... sit at home doing nothing like i did this saturday night :D
yes how did you go yesterday ken?
Hmm , might start charging money for rides. In the car that is ...:D
Got 4th o/r and 2nd 4wd behind Kevin Ledgers wrx racecar , a formula super vee and a track orientated westfield.
I was the first real roadcar and that's my excuse.
Niz , check your PM
Cheers
Ken
just been talking to micheal aka boxhead on MSN .... what did he do wrong ... hes not a bad bloke!
He might be alright but his constant refresh posts and arguing when someone queried the total uselessness of it all got very tiring.
His * if you don't like it **** off* attitude obviously pissed off enough people.
Cheers
Ken
Turbo's good lauren... just need to finish the project off and throw more money at it :D Really shows the need for a good ecu and some injectors and I think I need to get some really good brake fluid into the car now, the fluid makes a huge difference I am told, already got bendix ultimates on the front.
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
