  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bendix ultimates are ok Rob expect to wash your rims alot
depending on final power you may want to upgrade the front discs.
and if boxhead has been telling u he doesn't know why he has been kicked its total bull hes been sent afew pms by the head guys.
after all we been thru .... find myself still loving you .... cos i never give up on the good things .... never give up on the love we had
Sorry song stuck in my head and im bored ..... need someone to chat with.
Sounds like you are going through pretty hard time nizzy...
why dont you talk to someone who known you for long time like best friend or mom or what ever...
when I have problem I always talk to rexxy (even thought he is blind by new GF hahahah ) gives me good advice... what are friends for...
:D
mum - um how about noooo on that one
Best mate - doesnt understand - never had a boyfriend tooaught up in her own little world anyway.
Besides compared to what some people have to livfe thru guess its not a hard time. Just I keep gonig down the same path and never learn from it ...... and each time i do it just has the same effect ..... i chase after the wrong things.
Guest
