  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha Alex that picture so brought back memories of a sowing shop that used to exist in our suburb and mum used to take me in there to buy ribbons for my hair :)
yep sat or sun is good with me Kyles .... even next week i have weekdays free cos im no longer working if that suits you more?
lunch um dont know what im having ..... cant be bothered going into west perth so it'll be downstairs cafe shite no doubt.
Right, cant draw on the computer with a mouse!! LOL
How about this, each dress different style sort of. but they all still kinda look the same. All red, and to keep the racing checkered theme a checkered part down the sides (hard to explain that) .. see how that looks.. One dress, is hulterneck, one with just one strap on the side, one with 2 straps , one boob tube either a small slit up the sides, or up one thy.
checks down the side!! brillant i know what you mean :) that'll look mint! Yeah i was thinking different styles too - bit like they do with bridesmaid dresses these days so you can flatter everybodys shape.
i want halterneck tho - makes my chest look bustier :D
Guest
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
