  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL @ Niz... hmm well I'm met some "big" girls and I've met some "tiny" girls... all I can say is mmmm tiny... :P
Aside from that - I don't go looking at other bloke's equipment.. never had a complaint tho.. :D
probably part of reason shes now ya ex right?
u just dont say that kinda stuff .... nor do you ever ask someoneyour in a relationship with "How many people you been with" .... its just taboo.
i dun care about past boyfriends..... not really the jealous type. the way i see it, is if shes with me, she wants to be with me and thats that. if she wanted some other guy - shed go....
and my boss is ugly coz the only bloke she could land is 27 years older than her
Cam - you havent asked for a number have you???!! Thats just wrong - did ya get slapped?
Richie what do you reckon is an acceptable amount of lovers for a chick to have ..... always been curious about this question ... what defines a chick as a slurry?
yeah i never used to be jealous but my ex kinda said if your not jealous it means you dont care and all this shit...... depends how much i liek the person more i liek them the more protective i can be.
you asking me??? i wouldnt have a phucking clue. The only thing that would get me is if i knew the guys that a girl had been with and i have to say... work with them...
hey, each to their own... as long as when you are with someone the amount of lovers that you have is ONE... just them...
whats the acceptable number for a guy??
Guest
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
