  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, If you get on can you confirm that all those injectors are 550's, and have been flow tested? It's just there are a few different colours, wanted to be 100% before we tried fitting them:D
I was a bit suspicious but they have been checked and tested by Rotomotion.
The other set was similar but seems to be OK.
Cheers
Ken
Originally posted by Micko
Jarradale somewehere I believe mate - might go down there after I drop Naomi off at midday
Forrestfield oh deaf one...
CBH grain terminal on Abernathy rd bout 1km North of the Tonkin hwy overpass.
Cheers
Ken
My last post, the one about me being a good painter, please disreguard. Ravings of a bored housewife I'm afraid. 2nd coat not so good. See how it looks 2morrow.
Paul, not going on cruise. Night shift tonight.
I got the UHF radio from Tandy today, 2 for $99. Uniden, 3Km range 40 channel. Anyone want one? PM me.
Guest
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
    • Ran into this bloke trying to give Oscar some advice pre-race today.
    • Yeah I've personally seen the RB26 pull 30 degrees of ignition timing out of the base timing map if the ECU detects a cold start, it nearly starts misfiring because of it around 2000 rpm and it feels like the engine has no power. I'm just surprised that modern OEM control strategies are actually trading off efficiency for in-cylinder emissions. I would expect something like aggressive EGR dilution + tumble generation valve use to improve EGR tolerance to reduce in-cylinder NOx + HC from crevice volume while also reducing throttling loss vs pulling out some timing if not knock-limited.
    • *** DATE CHANGE *** Date has been changed to Saturday 17th May. The time and location is still the same!
    • You're more than welcome to - looking forward to meeting you!!  The turnout depends on the event and location... Pizza Runs on a clear night can drag out a decent crowd!
