  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Also looking at his power curve he has 12psi from 4000rpm onwards, which is good. I dont get 12psi till around 4600 :P It will be good to get the wolf3d into mine then we can all compare cos it will only be the turbo's that are diff on mine and aidwins car, you will have the manifold done so its a bit different but same ecu.
Looks like my car will be at the panel beater from tuesday till thursday cos I need it monday. Ah well, least I aint paying for the rear spoiler to be fixed up, its costing me $250 to get the boot lid latch hole welded up and painted, a pin dent and 2 key scratches to be fixed up all on the bootlid.
Guest
    • I’ve been considering one of these screens too, but I've heard mixed reviews about the software responsiveness. Some say it's great, while others mention lag issues. Before pulling the trigger, I'd check out a few recent user experiences to see if the latest models have improved.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
