  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah and after u buy the house be strick on yourself for a year, no mods just the necessities, and put all your pay into the loan
then after the year is up get a new valuation on the home then use that and equity u have in the home ie your repayments and the etra u've been putting in to buy a second house rent it out and use the rent to pay it off and then drop back on your house. do the same thing cercumstances permitting every 1 or 2 years
even when your just renting together the splitting of items gets messy .... plus living together you get to see the evil monster in each other - i think its best just to see what happens and give it another 6 months to a year before you decide.
Bad bad idea!
Originally posted by GTS-t VSPEC
Troy,
You should be able to do that already, surely living at home must mean you have lots of spare cash?
See'ya:burnout:
i live with my dad and brother not at home
we rent and my brother and i pay all the bills mum got all the procedes in the settlement
Originally posted by Strich9ine
we've been together for over 8 months now, and we understand that it'll be a financial transaction only...
i've lived with her before for a few months and she's not that bad, just wonder how she put up with me! hehehe
u know that buzzing sound when u left the room
thats how :D
why the hell would you want to get yourself in that much debt anyway eeek. Im waiting for my 21st for my little townhouse then use the rent off that to pay off the mortgage of a house i really want.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
