it prints all distorted
prints with coloured lines going thru the middle
and at the end it goes to carriage return and a swingarm comes up and grabs the cartridges and the cartridges keep moving.........crunch crunch.....
"warning" mechanism is jammed!! "
evry since the test page it has done it...
I followed all software took all the tapes out theres nothing stuck inside..i even uninstalled and got latest hp drivers from the homepage and somethings seriously wrong!
Ive done 2 test sheets and one calibration sheet and i had to leave it or else i was going to throw it out onto the road...
maybe im just not meant to have a printer....
whyyyyyyyyyyyyyyy!!!!!!!!!!!!!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I cant beleive it rob......
what do i do wrong???
yeah come round on sunday as a mate of course not for business :P
What it looks like is the printer is receiving totally different instructions kinda like its a total different driver running the hp
Anyway ive checked and rechecked lotsa stuff if u could have a look to varerify that would be cool
Guest
