  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
paul and brett u can keep guessing
my plates are ordered and on there way
u'll never get it
Yoda
Wookie
Skywalker
Luke4Eva
Starwars
HansSolo
Lightsaber
It'll be something to do with Star Wars.
my mum makes the best pasties (yes she cooked for once *shock horror*) So we had yummy pasties tonight.
I make the best casoroles - proper beef n red wine ones not that packet shite! - they are so yummy in winter!
Sneeza
Haven't seen you post for at least..........hmm.
bout a 100 pages of this garbage.
Hows the car or is this something we don't ask.
BTW , I have come to the conclusion that Niz does very little and pwptf does NO work during the day.
Geez you two can whore !!:(
Takes me 1/2 hr each night just to catch up on this Days of our lives thread.
Cheers
Ken
Joe - its a database type program I think - like mulitmedia databases. I think. It stores everything in a database. Its like a softwarre suite (like MS office) that has a web builder and stuff. Don;t know what programs - its all web stuff. I assume it would support java
Joe - here you go
ColdFusion has its own page markup language, called ColdFusion Markup Language (CFML). CFML encompasses the Web's Hypertext Markup Language (HTML) and Extensible Markup Language (XML). A just-in-time (JIT) compiler turns the CFML into the pages that get served. Allaire emphasizes that their product set is open and "extensible". Applications can access databases using Microsoft's OLE DB, Open Database Connectivity (ODBC), or drivers that access Oracle and Sybase databases. ColdFusion can be coordinated with distributed applications that use Common Object Request Broker Architecture (CORBA) or Microsoft's Distributed Component Object Model (DCOM) to interact with other network applications.
Guest
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
