  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Danny, Do you need extra time at SST other than the dyno day we have organised for the 5th?
Yeap, Have to setup puter to turbo setup that is in car at the moment. Bigboy is not sitting in its place at the moment (long story), Still should still hit 300rwhp but it will need some fine adjustment and a good tuner.
CYA there 2nite.
Morning Aidwin & Brett ...... dropped car over at panel beatrers this morning ..... it hit me this morning i wouldnt see her for two weeks ..... broke my heart.
Now im driving round in this oil chewing .... no radio .... power steering (doesnt feel like it) .... old bunky ford laser.
I dont care if the ZX hasnt got any insurance i drove this POS once and i absolutely hate it!!
Paul i dont have the money for a busfare at the moment let alone a cover note on the car. But it has to be reinsured when it goes ot the caryard anyway so i may try n talk my mum into covering it earlier.
Guest
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
